Hi guys I'm needing some advice.
I have a small room setup for off-grid , have got my hands on a 8.2kw inverter. Specs attached.
If I want to have say 2 standard gpos (Australian) connected to the inverter to connect appliances .what is the simplest and safest way to wire up ?
There isn't any existing wiring. Clean slate.
Since the inverter outlet is one single point , what's confusing me is the question of do I run cables out of that one outlet that can handle the 8.2kw load and amps to a breaker type box or busbar , then split off into the gpos front that?
Hopefully makes sense..
TIA
TIA
