I figured. Got ya. Worse efficiency at low loads, 3 percent loss at mppt stage, plus 80-120 w draw from 6000xpI believe what you are looking at is just the efficiency loss of the inverter. Remember that when we talk about 'idle draw' of a large inverter (which can range up to ~120w from what i've seen), that number actually scales UP with load on the inverter. The ~300w you're missing is probably mostly going on in the inverter itself. Even if the mppt section was only 97% efficient that would account for ~80w by itself. Not sure if the way you the numbers are being measured would account for that, though. The battery charging efficiency and inverter efficiencies are probably both in the lower 90s and making up the rest.
It's kind of unintuitive but considering that the inverter has a 'baseline' consumption, its actual efficiency at PRODUCING power starts out horrendous and gets better the higher the load is, although it might reverse and start trending downward again at some point. I dont know what the optimum load % for efficiency would be on an inverter but i can say for certain that it is NOT at light loads like 500w (assuming a large 3kw+ inverter).
Thanks for your reply.The MPPT efficiency is rated at 99%, but the battery charging efficiency at 93%. 93% of 2750 comes to about 2550 watts. The total of the power going into the battery plus the load power plus the internal consumption all pretty much adds up.
Just wondering if this is an issue. This is a EG4 6000 Xp going to a Victron shunt shown in solar assistant.
Yes, noted a 3 or so second time gap. Solar assistant does a MUCH better job than the EG4 software for updating the data.Load shown by SA is updated at a much lower rate
I came from a Victron SCC that was only a charge controller. Those things are TANKS and Victron VRM is awesome.I had the same question when I started using my 6000xp. This is my first AIO and coming from Victron SCCs that are very efficient at charing batteries from little solar power, I was surprised to see how much loss there was with this. In grid bypass it uses little to no power. Even when straight battery inverting the efficiency is quite good. But as soon as the MPPT kicks on the efficiency takes a huge hit. I don't have that much solar so I am not sure what I want to do yet.
They've made it easier to watch the money you "saved" buying value priced equipment trickle away.Moving to the 6000XP puts all the losses in the same spot and easy to measure. So good and bad I guess.
I have a victron SCC and an AIMs toroidal based inverter. I was under the impression that switch mode inverters were more efficient.They've made it easier to watch the money you "saved" buying value priced equipment trickle away.
True in a way - but the advantages for me more than offset the downside of losing a couple of kWh a day to efficiency losses. Going to be quite a long time before those efficiency losses are going to add up to spending 2-3X more for the equipment. Plus, in my case I'm getting more than enough solar even in February to cover my loads. Batteries discharge to 30-40% overnight and are fully charged by 1pm. Higher efficiency would only mean the batteries are fully charged a little earlier, but wouldn't equate to any difference in energy savings...They've made it easier to watch the money you "saved" buying value priced equipment trickle away.
You have nicely engineered a system that works with your AIO. Well done.Batteries discharge to 30-40% overnight and are fully charged by 1pm. Higher efficiency would only mean the batteries are fully charged a little earlier, but wouldn't equate to any difference in energy savings...
Yeah everyone’s needs are different eh. I might sing a different tune when I get more circuits/loads on mine next month when I get wired into the Pro Tran transfer switch. More loads overnight means the batteries will get lower and more loads during the solar day means less power going to the batteries for charging. Going to be a balancing act determining which loads to put on the solar system.You have nicely engineered a system that works with your AIO. Well done.
That act never ends.Going to be a balancing act
I have the shunt piped right into solar assistant via bluetooth on the raspberry pi. They are the same and in sync.What does the bluetooth app for the shunt show compared to what SA is showing
