timselectric
- Feb 5, 2022
- 19,285
Yes, we do disagree on this.disagree, we have had this conversation a few times.. there is zero export with a Ct on each mains. This allows the user to get the most out of the sun/solar panels.
Also allows for a much smaller much cheaper system that only has to cover high constant loads rather than being sized for infrequent high loads and surges.
in my area all I needed was an inspection to backfeed into the grid. I don’t backfeed, I save my excess in batteries but I do supply all my main panels loads. If the installation is done correctly and there’s a grid connection to the home, there’s no reason not have it inspected and approved and possibly an agreement if necessary.
when my batteries get low I don’t need to have an expensive inverter capable of 200amp pass through. The grid simply takes over and supplies the main panel like the inverter isn’t installed. Batteries recharge and inverter resumes covering/powering all of my homes loads it can up to inverters max output and grid simultaneously supplies the excess power up to the amp capability of the main panel.
And none of those loads the inverter is covering (all loads in main panel) needed to be moved out of that panel to a sub panel. Yes a few critical loads (needed to get by) can be moved to a subpanel so the inverters AC output can power those offgrid during power outages. Power outages are very rare for most people and are usually a very short duration. A much cheaper/smaller battery bank can get the user enough days of autonomy because only a few loads are moved offgrid. But the inverter that’s grid tie zero export is still zeroing their electric bill all the time.
Yes there’s a monthly fee to have grid power. Most have a grid connection. It’s VERY costly to have an offgrid setup that will allow for complete disconnection from the grid. For most people grid tie zero export is the most reasonable option and isn’t going anywhere soon. Most homes use way to much power to be offgrid. Once more people understand what grid tie zero export can really do and how much more efficiently it can use the sun and how much cheaper it is, more will start having setups that can achieve that, like the SolArk can.
Especially in the system cost.
