MartyByrde
Off-Grid Innovator
Gents, been looking around all day for an answer so I thought best to come to the forum.
I’m looking into running 240v equipment off-grid & outdoors. The new EG4 18k is $$$ so I found the MPP MPI15KW WP ( 15KW 48V) 230VAC. Not only is it cheaper but it allows a higher input voltage.
https://maximumsolar.online/product/1601/
I’m pretty good at figuring this out but hit a road block and need some clarification to point me in the right direction:
Since I’m entirely off-grid…
I’m running 240v machinery, so I don’t need an auto-transformer correct?
The grounding rod is bonded via copper wire to the inverter rather than the panel box?
Would I use a standard US breaker panel box, or do I need do use a European panel?
Paralleling two or more, I would bond each inverter to the same grounding rod via copper wire?
Any insight or personal experience is greatly appreciated!
