ladislavh
Hello,
Is there anyone who has working communication from JBD BMS via RS485 to Arduino?
I am using RS485-TTL conversion, but I am not able to get it working.
I found on the internet there is library to use UART, but I’d like to keep the bluetooth function as well. Maybe I will not avoid using that UART.
I’d be happy if anyone can share their solution, I need to display and work with data from BMS, it is not necessary needed via RS485, but as I said, I’d like to keep bluetooth as well, second option is manually disconnecting arduino from UART and inserting BT module temporarily.
