chaosnature
- Sep 15, 2022
- 456
Deleted
You are very right@chaosnature, perhaps it makes sense to start up a thread specifically to go through your setup.
There's more than just the JK-BMS to CANbus project that is being discussed here, so I'd like to spin this conversation off into a separate discussion.
Start up a new thread, tag me in it and I'll see if we can establish exactly what settings you need on the BMS, CANbus adaptor and the inverter itself.
No need to do that, we're just spinning off to a dedicated topic, that's all.You are very right
i will delete all the comments as it would deter others when they seek information
Just to update this thread that i have successfully added the second battery with BMS active balancing in playI don't think you can add additional cells for balancing and monitoring without increasing the total voltage. As you say, that's not something you can do with the Solis inverter.
I'd suggest buying another JK BMS that matches your current one, setting up the second battery with that and you can potentially be the tester for multi BMS logic when I develop it.
I realized what I did wrong - was supposed to order x2 of the actual esp32 and x 2 of the esp32s3 and i ordered x4 of the CAN isolation insteadAlso, I'd like to add my two cents to this amazing project.
I've prepared a summary connection diagram for those who are going to use the M5Stack—a nice product that simplifies the wiring and connections, making the hardware part almost plug and play.
Both configurations have been tested and are stable
here is the link to Atom S3 Lite@arzaman
can you please send a link to the M5Stack Official ATOMS3 Lite ESP32 Dev Kit i can only find the wireless
AtomS3 Lite ESP32S3 Dev Kit
ATOMS3 Lite is an esp32 development kit series using esp32S3 chip, its size is only 24249.5mm,This development board as 8MB SPI flash memory ,Wi-Fifunction, built-in 3D antenna,can be used smart home device,esp32 kits,rapid prototyping,supporting arduino esp32 ide.shop.m5stack.com
What’s the advantage of the S3 vs the one I bought below.
