Ok, seems I made a mistake thinking about the stuff, sorry.
Having the same port for charging & discharging, the electrical consumers are still powered by the charging device, even if the battery itself is cut off by a relay. So there is no necessity for a DC/DC buck step down inverter to be installed. That's because they are all connected to the same pols and so the circuit is still closed.
This means, the combination of a temperatur-sensor, having attached a voltage-controller at it's signal line and a SPDT-Relay hanging on the signal of the voltage-controller on the other hand would cut off the battery and pass the current to the heating pads by switching the circuit. This would probably work and the devices attached to the battery poles are still served with power by the charger itself. (I hope, I'm think right here)
If the enclosed voltage drops under the charging voltage controlled by the voltage-controller or the temperature rises over a certain value controlled by the temperatur-sensor the relay would loose its signal and switch back to the original position. The pads would stop heating and the battery would be connected again.
This assumes that the temperature-controller will pass the original circuit to the voltage-controller without manipulating its parameters. One could also do it the other way round, but I'm not sure how the more complex temperature-controller will react to a loss of power. Also the display won't work anymore. The voltage-controller on the other hand I expect to be more robust. It's missing the display and you set the voltages by two small Potentiometers.
Here are the components I'm thinking of:
- Temperature-Controller:
https://de.aliexpress.com/item/32867461365.html
- Voltage-Controller (battery protector):
https://www.aliexpress.com/item/32857358407.html or
https://www.aliexpress.com/item/32996091128.html (no overvoltage-protection)
- SPDT Relay: [still searching one with at least 200A permanent]
- Heating-Pads:
https://www.aliexpress.com/item/4000448687939.html
And the rest (already ordered
- Main battery switch:
https://www.aliexpress.com/item/4000183685881.html (300A cutting plus)
- Monitoring:
https://www.aliexpress.com/item/32888627400.html
- BMS:
https://www.aliexpress.com/item/32921950553.html (12V 4S 200A common port)
- CELLS:
https://www.aliexpress.com/item/33019962665.html (8S, always two of them in parallel)
EDIT: The case is very limited in its dimensions. Max. 350x370x210mm is everything I have, so insulation is also very limited, too. That was also the reason to buy these cells, they simply match very well in size (especially height), although it seems like I'm going to get B-cells. We'll see...
