I assume you want to know if small wind makes financial sense? The short answer is not even close at any height. Many make great claims but none can supply one shred of data to actually back up their claims. I'm talking about annual energy (kWH) data, not a snap shot of power (kW) during a high wind event.Hi has anybody installed successfully a micro wind turbine on a 5 meter or 10-meter pole in the garden? does it work? We get easy winds of 10 miles per hour practically all the time, a lot of the time more than that.
You should! Please set up some kWH data logging on them and then report back in year. I'd love to hear a small wind success story.I own two… I suppose I could mount them and see…
My problem is trees…You should! Please set up some kWH data logging on them and then report back in year. I'd love to hear a small wind success story.
Most of my available yards have 160’ trees surrounding them. I got the turbines dirt cheap on clearance, before I learned how high they need to be placed…
I do own a 80 meter crank up tower for HAM radio… but it takes a LOT of concrete to mount.
Anybody in an area suitable for a windmill want one?
I have made wind turbines
This is one I am working on at the moment , I have a 6m tower it will be going on , cheers.
<iframe width="560" height="315" src="" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
The rule of thumb is 30 feet above nearby tree-top height, minimum. That being said, I had a small-ish turbine work OK at 10 meter height (30 feet) when there was wind. At low height, the wind can be turbulent which hurts your average power output.
Did you measure this 10 MPH wind ? That is not really high enough wind speed. Wind gusts don't really mean much but....
I'd put the turbine up as high as you can get it. That will help laminar (smooth) wind and get higher wind speed.
Wind is definitely fun ! Wind MPPT also works well.
Sounds good (but is it all advertising crap) https://www.amazon.com.au/Turbine-G...9&psc=1&mcid=a43f6670e88c344d875e44309ac3b614
