SpongeboB Sinewave
Yes, you can just hook it up. Just make sure it does not try to go over 150V otherwise the Classic will open up and let it go higher and higher.
But without being in a "storm", just wind, you should be fine. Try to pick a default startup turbine graph for wind-track that is the right battery voltage and close to input startup voltage that you want.
IF it just stalls again, you just may not have enough wind today ?
boB
boB
