Right. And no inverter should ever overcharge a battery, either. But sometimes they do. Which is why BMSes are so important.
They do? The only times that I have seen an inverter overcharge a battery was when the settings were made incorrectly on install..... That would then be installer error. But maybe I haven't worked with enough bottom of the barrel cheap inverters...??
Constant communication is another level of protection. Without it, if there are no other failures, everything should still work OK. With it - there's another level of protection. Which is why such systems are safer.
If the battery gives a charge target voltage of say 55.6V with a max charge amps of say 150A, (let's call it a 300AH, 48V LFP scenario...) then the battery loses comms with the inverter.... The inverter will keep that target 55.6V charge setpoint until it is told differently! When it hits 55.6V it will throttle back charging and just hold the voltage there! If the batteries will have adverse effects from that, then there are other issues! (Such as the question of why the BMS gave a charge target that it couldn't handle......) The inverter will NOT charge higher than that setpoint if it is a reputable inverter! If you can't depend on that then you need to scrap your inverter and start over! And if your battery has adverse effects because of the inverter charging up to the voltage setpoint, at or below the max charge amps setpoint, then your battery needs to be scrapped and you need to start over!
I have been involved in hundreds of LFP battery/inverter/solar setups over the last number of years, and probably 95% of them did NOT have closed loop comms! And guess what.... those systems have had less call backs and service calls than the closed loop comms ones! Closed loop comms is in NO WAY a miracle fix-all! In fact closed loop comms adds a layer of complexity to a system! If people are not too lazy to do their homework on proper parameters and setpoints, a system can work very well without closed loop comms!
Now I will say that on a high voltage battery (in my opinion anything over 100ish VDC really...) there SHOULD be closed loop comms! That is a whole different animal!
Don't be offended by what I am saying! I am simply spouting what I have learned and/or worked with over the years!
My personal conclusion is this:
Pros of closed loop comms=
- installer doesn't have to set charge volts and amps
- battery could theoretically tell inverter to slow charging on internal high temp (not likely to happen unless there is a loose connection... so this is sort of a moot point really... and furthermore I honestly think most BMSs would just completely shut down on overtemp without ever throttling charging, turning this into a non-elligible "pro"....)
- battery tells inverter the SOC (because some inverter brands can't accurately track SOC these days....) NOTE* this "pro" depends on the BMS to accurately track SOC, which many actually don't!
- Someone tell me more pros.... I can't think of any, really.
Cons of closed loop comms=
- installers are more likely to get lazy and not research the batteries and how they work because they can just "plug and play". This results in systems that don't perform well, or as they should!
- dependent on BMS to work properly, for inverter to work properly. BMS bugs will affect inverter performance and potentially cause power outages, glitches, etc. (I have worked on many systems that power offices, where I'm in trouble if there is a power outage or power glitch!)
- dependent on comms cable connections to not corrode. Sometimes inverter get installed in less than ideal conditions where they may potentially be more subject to corrosion..... Not ideal, but simply a fact of life when it comes to inverters and batteries!
- no universal protocol for closed loop comms, therefore you can't use just any battery with just any inverter. Some may think this is beneficial, I feel this is detrimental to the industry!
- Closed loop comms adds another layer to troubleshoot when there are issues! As someone who has done much troubleshooting over the years, I appreciate when things are done in a simple and easy to figure out way! Some may say, oh but you can hook up a PC to the BMSs and see what's going on... But why do that, when there is an option to not need that? More tech is not always better!
Bottom line: personally I prefer open loop, even though we are using quite a bit of closed loop batteries these days!
I know for a fact that when you understand how the batteries work and what each parameter in the inverter menu does, you can create an open loop system that has as good or even better capability than closed loop!
You are entitled to your opinion, as am I. I don't know about you, but I have formed my opinion from a number of years of installing and working with batteries and inverters!
