Hoping someone has tackled this ...
I have beautiful communication between python code and the Insight Home with modbus. Got it down the a 100% reliable science.
I still have a ComBox that I wish to use and thought it should be easy-peasy to use almost identical modbus code to do so.
I had no trouble going from gateway to Insight home and back again.
What does the ComBox expect that is different than the later Insight/gateway boxes ?
Is it port number, something to do with a slave parameter ?
I cannot even get to ComBox for the device name at address 0. Yet the gateway responds.
Yes, both boxes are two different IP addresses. And I have two totally different XanBus's to the respective inverters.
fyi - the new stuff is xw6848 Pro and the old stuff I want with the Combox is xw4548.
Both Combox and gateway work fine on their respective local webpages. So I have no issue with config'ing 'em all.
Thanks.
Thanks.
