garybryan33
Seg Yukon 460-watt bifacial panel specifications:
Front:
VOC: 41.50
VMP - 34.49
ISC - 13.96
IMP - 13.34
Rear:
VOC - 41.52
VMP - 34.49
ISC - 9.84
IMP - 9.34
I have 3 strings of 8 panels feeding an EG4 18K, 2 strings will go into input 1 thus paralleled, and the third string will go into input 2
The question is, What ISC value should I use to determine the amperage of the paralleled strings?
As I understand, If you have solar panels connected in series, the total current passing through the circuit is limited by the panel with the lowest current output. In this scenario, if one side of the panel produces 13.34 amps, and the other side produces 9.34 amps, the current is limited by the 9.34 amps (the lower value). This is because the current must be the same at all points in a series circuit. All that to say, which one is correct?
8 panels in series:
volts: 332.16 volts: 332.16
ISC: 13.96 OR ISC: 9.84
Watts: 3680 Watts: 3680
Paralleled
volts: 332.16
ISC: 27.92 or 19.68
Watts: 7360
Thank you
Front:
VOC: 41.50
VMP - 34.49
ISC - 13.96
IMP - 13.34
Rear:
VOC - 41.52
VMP - 34.49
ISC - 9.84
IMP - 9.34
8 panels in series:
Paralleled
volts: 332.16
ISC: 27.92 or 19.68
Watts: 7360
Thank you
