- Multiple charge sources?
- Description
- Hi, first of all, I'm a complete newbie, so apologies if my question is stupid.
- In essence, my question is - can I connect several charge sources simultaneously to a battery.
- On the face of it, its a stupid question but in reality I have a cheap solar charger connected to my tractor battery so that I am never left with a flat battery, but when I start the engine the battery is getting a charge from both the alternator and the solar charger, hence two sources in parallel. With a rudimentary lead acid set up, this probably isn't a problem but when applying the same practice to my motorhome it starts to get expensive and fire is my worst fear.
- Now the real question.
- I am considering upgrading the entire power system in my American Motorhome. It has a solar charge system already but it uses Lead acid batteries and is quite basic. My plan is to base a new system around the Renology 12V 300Ah Deep Cycle Lithium Iron Phosphate Battery. SKU: RBT12300LFPSH-UK. Most likely 2 batteries but possibly 3.
- I plan to use the DCC50S 12V 50A DC-DC On-Board Battery Charger with MPPT(New Version) SKU: RBC50D1S-UK so that I can charge from the vehicle alternator when on the move. I would like to also incorporate the 3000W 12V Pure Sine Wave Inverter Charger w/ LCD SKU: R-INVT-PCL1-30123S-UK into the system as well. Which would provide AC when required and also a handy Lion compatible charge capability when connected to a shore supply.
- I have 2 queries.
- A) the DC-DC charger has a max solar charge current of 25A. Where as some the other solar charge controllers have a much higher rating i.e. the Rover 100 Amp MPPT Solar Charge Controller SKU: RNG-CTRL-RVR100-BT-UK1. 100A is possibly overkill but 25A might be too low, thus can I connect two chargers i.e. the DC-DC to charge from the alternator and a separate PV charge controller simultaneously (i.e. in parallel to the same battery). Potentially both chargers could operate at the same time i.e. engine running thus charging from the alternator via the DC-DC and the separate PV could be producing a charge at the same time. Would the two chargers interfere with each other?
- B) in very much the same way, would connecting the Inverter / charger to a shore supply, thus causing it to also produce a charge cause a problem? In this instance I could potentially have 3 separate charge sources connected to the same battery. i.e. engine running thus charging from the alternator via the DC-DC plus the separate PV producing a charge at the same time and also the inverter / charger producing a charge because it's connected to the shore supply.
- Assuming the above is possible, could any provide a schematic of the required components to create a system that can charge the batteries in all of the 3 situations above i.e. alternator / PV / ac charger (in-built in Inverter) that would be fabulous
