Quirks using the nhx as a solar battery charger only:
No communications with battery bank so using lead acid setting. Instead of showing voltage on the home page, it shows %. Does not show amps going to the battery on the homepage either, only % and kw.
Set max charge at 100amps. When the last array was hooked up, the battery menu sat at 99.9amps charge. Went into settings and changed max charge to 120amps. The battery menu went from 99amps to occasionally bumping 102amps but the battery icon still says max charge 100amps. I do not know if it took the new setting or not.
