well i really dont need communication between inverter and bms. I see some brands, Daly, JBD, JK, i am kind of lost here. Could you point out a model that you would recommend?I would base my decision on which inverter I was using and whether I wanted communication between inverter and BMS.
Thanks, i will take it into considerationIf you need the battery to push more amps than the bms can supply, you can always add a contactor. This is a large relay. What happens is the bms controls the contactor and the large load goes through the contactor.
For my system I used a contactor based bms. The contactor I used is a Tyco EV200AAANA (that’s the 12-36v one - they have a 48v one).
Good Luck
this is my system, i have 3 voltronic max axpert 8kw each, and also i have 3 orient power server rack batteries (jakiper battery clone)What is the inverter? No communication between these two has both pros and cons. An example is SOC drift on the inverter side and having 50% charge in the battery, but the inverter shutting down due to low SOC.
But if you don't need communication - JBD has a 200A inverter with an active balancer.
yes the more i look into it the more it looks like something like 100A would be enough. What do you think about the seplos smart bms?You really don't need a 200A BMS if you are paralleling with the batteries already in place. 4 batteries in parallel would split the load. The battery bank I built has 4 batteries in parallel. Charging at 120A is 30A per battery, discharging at 160A is 40A per battery.
I run a Batrium on my house bank. I have several JBD/Overkill and those work well.yes the more i look into it the more it looks like something like 100A would be enough. What do you think about the seplos smart bms?
I think it is the JK which has the active balancer.JBD has a 200A inverter with an active balancer.
I currently use JBD BMSs one of which has a contactor and I would recommend that brand based on personal experience.Could you point out a model that you would recommend?
I am looking to the JK and they look good, however my batteries (and a lot of other brands) use a bms that looks like this. This is the seplos smart bms. Are these any good?
