You could potentially achieve this with a (cheap) very small capacity battery, which could buffer the effects of intermittent sun loss.
Thanks for your interest, I invited all thoughts and discussions, the main point of the project was to dump the costly batteries and make a maintenance free PV power system, my older system needed 4 new deep cycle batteries at $2,400 replacement cost. It became apparent to me the Exidy battery company was the big winner in my solar adventure to go green and save some cash.
Currently running main A/C 120VAC mini-split, Fridge,lights and more off the 18 12VDC solar panel 180VDC configuration groups of 9 series solar panels, Grid/Secondary power is making for a good solid platform to support intermittent clouds and after hours operation.
The system as it sets is 98 percent good,
Has performed well for months now, I will detail here the remaining potential issues, Ever had it raining in the front yard and sun shining in the backyard? This will cause a resetable fault/trip also loss of Grid/secondary when PV energy is not enough will cause a similar trip. (Currently blows a 10amp glass fuse but will soon be replaced with a easy to reset breaker.
Have considered super capacitors and other forms of temporary energy storage but the cost quickly rises to the point where your back to purchasing batteries again, The current project DIY cost is under $3,000 planning on additional 9 solar panels for the full array so let's just round it up to $4,000, other system have price tags of 25,000,36,000,39,000 and 69,000 payment plans. I suggest you do the math for your self and study real customers reviews before putting a pen to paper.
Maintenance on the DIY system consists of keeping the PV panels clean and resetting the system once in a while my best guess is once every three months or so.
The system preforms above normal expectations in overcast conditions and in full sun the presence of Grid voltage at little to no current excites the panels into producing noticeably more energy.
Much more study needs to be done here on this, early testing points to big difference in type age and construction of the solar panels with mono silicone having a noticeable advantage, In the other thread is two quartz tube heaters in side by side photos the one on the left is dim directly driven PV, the one on the right voltage boosted with Grid voltage but zero current draw, all I can tell you the one one the right side feels great on a below freezing day.
If you want to see it for yourself put 9 standard 12VDC panels in series, be careful 180VDC! in sunlight, and claim the 180 volt Deluxe Inverter being offered for free in the other thread, no strings attached but if you like it just tell others about it, great head start to the full system.
My aim is to have as many working examples of this unique power system as possible before my retirement ends.
Best wishes to all
