orangezero
- Sep 20, 2020
- 92
I want to find a way to use two old home theater subwoofers with failed amplifier boards. I also have two Jensen XDA92rb car audio amps which run on a typical 12v car battery, around 240w rms @4ohm (600w peak) which matches well with the subwoofers. I have a 24v 200ah lifepo4 battery charged with solar panels offgrid. I've used a smaller 14v lithium titanate pack to test one of the amps and subwoofers and it works well.
I'd prefer to run them both from my solar/battery on 24v and not use AC at all. So, do I need to get a 24v to 12v converter... that seems expensive to get a proper sized one... or is it possible to wire the two Jensen amps in series? The amps are 16v max input listed, so it can't be as easy as 26v/2 gives each amp around 13v? Is it? I assume there are good reasons to not do this, but can anyone point me to a discussion of why?
I seem to remember my inverter didn't like powering one of these subs when it was using its built-in amp, meaning the inverter would reset occasionally.
As I write this out, I'm wondering if the best answer is to just use the lithium titanate pack and keep recharging it. Didn't really want to go down the path of figuring out how many hours of use I could get before needing a recharge.
thanks
thanks
