underdog5004
I'm planning to set up a new array specifically angled for winter. the panels are going to be pretty steep; most of the array can be lagged into the side of my house but about 10 ft or 15 ft of the array will extend past the edge of my house. to support the rails in this section I'm planning to put in two or three 10 ft post into the ground about 4 ft and then put concrete in the hole at the base. will this be sufficient or should I do something different? A deeper hole? more bracing? Something else?
At this point I'm planning to use Redwood 4x4 post with no pressure treat 10 ft long. 4 ft in the ground leaves 6 ft above ground to tie into
In the area where the fence post will be supporting the array I will have about four panels each about 30 lbs.
I'm not very worried about wind load because the array will be extending into kind of a pocket at the back side of my house where the house goes in and back again so I'm really kind of blocking off a corner or an inverted corner of the perimeter of my house
I'm pretty new at doing these posts so any advice is welcome!
