I am designing a roof-mounted 16 kW grid-tied system for my home and want to avoid unnecessary wiring expense. The solar panels will be installed on a detached garage/barn ( 36 panels ) and connected to a string inverter. The distance from the garage to the service entrance location in the house is approximately 100'.
One possible config would be three strings of 12 panels each, giving a VOC max of 500 volts and a max DC current of 32 amps.
Initially, I was considering running the DC from the solar panels to a point near the service entrance and install the inverter close to the main breaker box. This would entail trenching, laying new conduit, punching another hole in my foundation, running 100' of 8 gauge (minimum), etc.
However, there is an existing sub-panel in the garage that is fed off the main house panel with a 240volt, 100amp circuit over 2 gauge wire. If my calculations are correct, the string inverter AC output would be well below the load carrying capacity of the existing wire/breakers/busbar.
Would it be possible to install my inverter in the garage and tie it into the sub-panel, thereby avoiding the expense of running new lines from the garage to the house?
Any help would be greatly appreciated!
