Renogy RS-485 communications interface...in detail
Cbull
See attached pdf file for details concerning Renogy's RS-485 communications interface...should\could be helpful for anyone else that's tired of Renogy's BlueTooth external adapter inconsistent connectivity.
  • Charge Controller RS485 MODBUS Protocol V1.7.pdf
Using a simple RS-485 to USB adapter (model UT-885...uotek.com) cable pin out;
RS-485 to USB adapter Renogy DC-DC unit RS-485 (RJ-45 connector) interface
pin 1 (TX\RX +) pin 2
pin 2 (TX\RX -) pin 3
pin 5 (grnd) pin 4
I have the Renogy DCC50S with the BT-2 bluetooth monitor and the RMS-DCDC monitoring screen and I'm trying to get the 2 monitoring units to work with the DCDC charger.
I don't need the BT to work while I'm driving but would like to use the monitoring screen so my idea was to use a 4PDT relay to switch the screen in with ignition and have the BT unit working through the NC contacts when engine is shut off.
I'm only using contacts 1-4 as shown in the PDF as I assumed the Canbus contacts could be ignored but it doesn't work.
I notice the the RJ45 pin numbering on the image in the PDF seems to be reversed i.e. numbering from 8 to 1 from the left. Do the numbers & allocations in the list actually correspond to the numbers shown on the plug?
Thanks for any enlightenment or guidance!
Just answering my own question, I found that pins 5 to 8 work correctly. The PDF is showing non-standard RJ45 pin numbering.
So I now have the RMS-DCDC screen showing while ignition is on and the BT-2 working when I shut down.
Sorry to revive an ooooold thread. Wondering what cable you guys might recommend for this today? I cannot buy the Renogy official cable.
Looking at Renogy Document for the cable - https://www.renogy.com/content/RSCB1.8M24/SCB-Manual.pdf
It references using the "FT232RL" chip.
Would something like this work: https://www.amazon.ca/gp/product/B07N1LZSBN/ref=ox_sc_act_title_1?smid=A1SRKLXY0XF9L5&psc=1
Its suppose to be the same chip. Just no guess on the pin out. I am trying to wrap my brain around it.
I want the cable to do a couple things.
- I have a few of these batteries and they are on a few different firmware versions. I am hoping to update them all to the same.
- I have seen the dbus-serialbattery project ( https://louisvdw.github.io/dbus-serialbattery/ ) that I should be able to add the BMS directly to my Cerbo (Raspberry Pi).
Any advice is appreciated.
Hello,
did you manage to connect Renogy LiFePo4 to Venus Pi? I want to by 3 of these batteries but I didn't find any info about connecting more than one battery to Victron Venus.
Thanks
Hello,
Thanks
I paused the project for other higher priority stuff for me... In the end I can use the renogy bluetooth for what I need. Saying that I would like to get it working. It looks like though all I need is to install the dbus software and a renogy official cable for programming an updating the batteries. I could not find one to order though so I have to make my own and could not find any good info short of guessing a little.
Would love to hear what you come up with.
Hey there. I'm going to give this a shot with a Cerbo and see what happens. I'm going to use a generic RS485 to USB interface since it appears the Renogy model is no longer available. I think the problem I am likely to run into is that each battery will somehow need to be assigned an individual address/drop number. It appears that this uses modbus protocol, and I would expect that each battery would be factory assigned the same address. If I want to connect to multiple batteries with the same connection (in my case 4), then I would need to figure this out. A workaround would be to put an RS485 to USB on each battery and run them to the Cerbo individually, but that seems like a messy set-up when you can daisy chain the batteries together and use a single connection.
EDIT:
Looking at your Amazon link, it appears the adapter you were looking at is RS232, not RS485. Same language, different protocol. RS232 doesn't allow for multiple devices where RS485 does. The Renogy batteries are RS485 devices.
Waking up an old thread again... I have a Renogy battery and was wondering if anyone had made progress? With regards to the device address,
the linked document doesn't appear to state anywhere what defaults might be, but for "PDU"s you can apparently read and change it with the register at 0x1A. I'm waiting for an RS485 interface but presumably I can then poll all device addresses to find out what address my battery has, and then scan register addresses to find undocumented ones, and if the contents of one is the same as the device address it's a good indication that it might be.
