soylentgreen
- Apr 23, 2021
- 91
I'm in SDGE and have a 5KW Solar grid tie system on NEM 1.0.
Over the years, my electricity consumption has gone up, as I've changed or added:
- ICE car -> EV
- gas water heater -> heat pump water heater
- gas furnace -> heat pump
- new spa/hot tub (~ 200kWH/month)
I'm now using about 200kWh / month more than I generate with solar, which costs about $100/month (averaged over the year). I'm on the normal DR-SES plan, and under NEM 1.0 I get 100% credit for kWh I feed to the grid with a yearly true-up.
I feel good about not burning so much fossil fuels, but I miss the $0 energy bills.
Ideas about what I could do:
* Add more solar panels (about 1500W would do it). I'm guessing this would cost $5k. This would be my first choice, but if I add more than 500W (10%), I think I would lose NEM1.0 and have to move to NEM 3. Is that true?
* Switch to EV-TOU5 (which has a $16/month fee, but gives super off peak rates of under $0.15/kWH). Schedule electricity use to fall within cheap TOU hours.
* Switch to EV-TOU5, and build my own battery storage system, and do time-shifting arbitrage. I would probably use Victron inverter/charger (since I already have Victron kit) and 48V rack batteries. For about $6k I should be able to get a 10kWH system which should sufice. I would build this myself, and would not apply for rebates. My understanding is that I could legally do this without approval or permits. (true?)
* Pay a professional to install a battery backup system, probably replacing my grid-tie solar inverter with a hybrid inverter. This would cost more, and require permitting, but might quality for rebates etc.
* Get a heat pump for the Spa - a RayPak Crosswind 30I would cut my heat pump use by about 75%, and cost under $2000. It could be better than that: My current spa is 120V and only heats at 1KW (about 1F/hour), meaning I leave it hot all the time. The RayPak could heat 5x faster (raising the temperature about 5F/hour). So, I could leave the spa at 90F (reducing heat loss) and only heat it up on nights I plan to use it.
* do nothing! Paying $100/month for a pure electirc household is pretty cheap, and given the uncertainty of SDGE / NEM rules, I should just grin and bear it.
What would you recommend?
- ICE car -> EV
