jassdhali
Hi,
As title suggests I have assembled a Seplos battery pack with a v3 active balancer.
Just waiting on cable to setup up BMS & a few cables for my Sunsynk 5kW inverter.
I was recommended to use a Neey 4A Active balancer, this was before I realised I had one on the Seplos system
I have assembled the battery pack & all the wiring as required, as to set a baseline, due to the fact that I have never put one together before.
Having the Neey balancer in hand. I wanted to remove the wiring for the Seplos active balancer, but I have a connector lead going from the BMS to the v3 balancer,.
This lead is referred to as the 'dry contact wire' on the instructions.
My question is will this have any impact on the BMS if I leave this wire off to isolate the v3 balancer.
I hope this makes some sense
Thanks for your time.
Jass
Jass
