Solar Assistant and Output Source Priority
30362
Hey all, this might be a stupid question, but I've tried several times and I'm not able to get SA to behave, so hoping I'm just missing something obvious.
I would like to set the inverters to use SUB for output priority, however it appears that when I set that directly on the EG4s that SA is still changing it back to SBU.
How can I set the default to SUB so that I stay in that mode versus having to set output priority in SA every 23 hours or so?
I've tried setting SUB on the inverters at the panel and cancelling any output source priority override in SA, but SA flips into SBU.
I've tried setting SUB in SA as an override, then cancelling, hoping it just stays in that mode, but it flips into SBU.
