BearSimple
- Nov 19, 2019
- 3
I am thinking of getting the Renogy DCC50S. I like the idea of one simple controller that charges via the alternator and/or solar. I directly charge only off the alternator now. Adding 300 w of solar to the roof of my van (3 panels 100w each). I have 250 ah of AGM batteries now. I have a few questions/concerns:
Thx in advance. First post here.
- Solar panels in Parallel - I have read a lot about the best way to set up solar panels is a combination of series and parallel. This gets the voltage up faster to charge more when there is low amount of sun. You can't do that with this unit because of the voltage limits. Is that really a concern? Does this handle lower voltages better because of the lower limit?
- Super simple but no Bluetooth - I see that many nice systems have a Bluetooth option for controlling and logging of the data. This does not offer that. Any concerns with not having that?
- Trickle charge - I will be using this with AGM batteries but might get Lithium at some point. I see that the system trickle charges and starter battery when everything is charged up. There is not a setting for starter battery separate from the solar batteries. Is this a concern? I don't think that trickle charging is all the same for different types of batteries?
