This is what I thought I do not know if super Caps can be used as a an AC mechanism. But if you had a full bank of DC superCaps they would not increase the Inverters max surge power.
Sorry for being late to the party, but I believe I do have something to add.
First, what we commonly refer to as "super capacitors" are large capacitance electrolytic capacitors. Being electrolytic, they have polarity and CAN NOT be used
(directly) in AC CIRCUITS ! Side note, anyone who as even just glanced at these devices will note that they tend to be low voltage, commonly 2.7V. You would need 6 in series for a 12V application.
Second, when trying to start high load AC devices
(pumps, compressors, etc) the issue is limiting "in rush" current. Time for some simple electrical engineering lessons !
Capacitors "resist" change is voltage. When a capacitor is not charged, it will look like a short circuit to a power source,
drawing as much current as possible. Adding a large capacitor between a battery and its load
(such as an inverter) works, because the battery "looks" like a inifinite current source (for a short period of time).
Inductors
(pretty much everything has some inductance), "resist" change in current. Once it is fully "charged", it wants to stay that way and maintain its voltage. Also, when a load is quickly removed, the energy stored in inductor
(motor windings, light bulb filament, etc) has to do something with that energy
(stored in a magnetic field), so as the field "collapses" it generate a high NEGATIVE voltage spike.
When starting a large inductive load the key is to LIMIT THE IN RUSH CURRENT ! CAPACITORS DO NOT LIMIT THE IN RUSH CURRENT ! What you need is a device that limits current until the load can "ramp up". For AC high inductive loads, something like a
MicroAir EasyStart™ 364 Soft Starter will do the job.
