Bluedog225
Texas
- Nov 18, 2019
- 3,012
Good morning,
Is there a downside to putting a small solar panel trickle charger on an AGM battery in long term storage?
I’d pick it to roughly match the discharge rate of the specific battery. E.g.: 20 watts directly to the battery terminals with no charge controller.
And if I did use the trickle charger resulting in a constant high voltage, I’m reading the text below to say that a boost charge every 90 days is still required. Does that sound accurate? The instructions are below and I could read them either way.
Also, is there a way to have an automatic boost charge applied every 90 days in the Victron ecosystem?
Thanks
Thanks
