hi all
Im looking for some best practice guide lines in terms of mounting the physical cells for anti-vibration in a van.
The cells I am using are the blue aluminium/plastic cased ones. My system would be a 8S2P 320ah 24v cell system.
In my van I have 1" polyiso floor with 1/4" plywood over the top. I was thinking of using a 3/8" closed cell foam sheet between the plywood floor and the plywood base of the lifepo4 battery pack for anti vibration. Is this a good idea? or possibly a bad idea?
I have some m8 anti vibration feet similar to these https://www.aliexpress.com/item/100...4!sea!AU!120920609&curPageLogUid=8Mrbnp0GHrmP but im not sure how much weight they could hold. 8 cells would be over 100lbs.
I will build 2x cradles for each 8S configuration and be clamping the battery cells with 4x threaded rod/nuts, 11/16" plywood ends, with 1/16" rubber in between each cell and the next ,as well as the cell and the plywood ends.
Thanks
Thanks
