MountainmanBill
- Feb 20, 2021
- 69
I don't get it, or, what am I missing? Looking at the manual for this device it states:
3.5. Basic electrical connections Connection procedure: 1. Connect the negative battery terminal to the M10 bolt on the "BATTERY ONLY" side of the shunt. Tighten the shunt bolt with a maximum torque of 21Nm. Note that there should be no other connections on this side of the shunt or on the negative battery terminal. Any loads or chargers connected here will be excluded from the battery state of charge calculation.
For one thing, my battery terminals have a 3/8" stud that will not accept that little 10mm wire terminal provided with the shunt. For another, that little wire that goes from the negative battery terminal is no way going to support all the amps going out of the batteries and to the inverter. My inverter has to have a 1/0 cable to perform adequately so things aren't adding up, or I just understand what's going on here. Help in the understanding of this device would be greatly appreciated.
