wattmatters
Solar Wizard
The MP II do not have solar charge controllers like the AIOs do, so add those and the extra cabling/connections to the price. If you are in the smaller system side, and have the space for the extra components then you can probably do OK with Victron kit. But once the power demand goes up, the price goes ballistic.You can do a bit better than that at times too. I picked up a spare 5kva MP2 last month for just under $1500AUD with a discount code on eBay. That puts it only $3-400AUD pricier than the cheap chinese HF AIOs like growatt
To replace my 8kW AIO I would need the 8kVA MP II plus a separate higher voltage charge controller (in fact I'd probably need the 10 kVA MP II model as the temperature power derating of the Victron inverters is so harsh for Australian conditions). That's ~$4k plus $2k for the higher voltage charge controller and extras for hooking it up. I'm looking at $6k+ and I don't have the space for it.
An 8 kW Voltronic AIO for under $1.9k.
Or a Growatt 12 kW for $2.7k.
Or a Deye 8 kW for under $3.8k. The Deye is CEC approved and IP65 rated.
All these can work with Solar Assistant / Home Assistant for amazing monitoring/controllability/flexibility.
