Ariel188
Hi all,
The percent of my system charged keeps going down, down, down. It was at 100% a couple months ago, but now it's stuck at topping off at 77%. Even with full sun or generator, it will NOT go above 77%! It will not go to Absorption or Float ever anymore...... It just tops out at Inverting or bulk.
This is becoming an issue as the % keeps dropping and dropping over time......
It's a 48 volt system, with four 12 volt chin 300 amp hr batteries that are tired together in series with battery balancers.
How can I fix this issue, and get my charge to 100%? When I have excess power, I still never see absorption/float. It's stuck at inverting.... wasting power from my solar panels not going into my batteries......
Like right now, I have FULL sun on the panels, and it went from charging over 2000w to changing only 350 watts because it got to 77% but still says inverting. When it stopped charging in the past it would say absorption and then float, then you know your are truly at 100%.......
I hope that makes sense. Thank you so much!
