So,I have a jumper connecting load neutral to chassis in my inverter.
Maybe called a N-G bond? Not sure of the terminology.
Does this wire need to be a particular gauge to be effective?
Currently it's just a very thin 18AWG.
@FilterGuy Thanks for your response. Deye 8K inverter.What Wattage is the Inverter?
That's right homie. Not only did I invent the electron, but I can turn off the electron at will, so it's best to stay on my good side!
Depends if you use islanding mode.I have a jumper connecting load neutral to chassis in my inverter.
So.... 8KW is 8000W/240V=33A. The jumper should be an 8AWG@FilterGuy Thanks for your response. Deye 8K inverter.
