Onehand
And how would you connect 2 pos and 2 neg to the battery rack buss bars if stacking is a no-no and assimilates a Lincoln are welder?
Seems to me I should run, as a minimum, 1/0 cable from XP's, to small buss bars under the inverters in parallel, then only one pair of 2/0 from the small buss bars under the inverter to the battery rack in the diagonal fashion, with a 300A T class fuse. Either that or upsize to 2/0 from the XP's to buss bars under the inverters and then run one pair 4/0 to the battery rack buss bars with a 300 amp T class fuse on the 4/0 pos line, near the pos battery rack buss bar feed point. Better Idea?
Wonder if 200A fuses would be warranted on the 1/0 or 2/0 short runs from the XP's to the small buss bars?
Sig Sol says 1/0 is fine, looks like another cut corner to me?
