I have only one leg of my pv array running through a breaker. I have a Growatt with 120-250v mppt input. The array produces between 200-220v. The breaker is a Midnite 300v I believe. It is a double breaker that is hooked in series. This is the setup that was recommended when I purchased this equipment.
Should I add another to break the other leg? The way I read it I need to. I did get a tingle once when finalizing the setup of the array. The breaker was off but the panels were not fully covered when this happened.
My ground is held to the Ironridge rails with an Ironridge ground lug. It then travels through a conduit to the ac breaker panel busbar. The Growatt is attached to the AC breaker panel with a 3 wire conduit/Wire whip. The ground wire is attached to the ground lug in the panel then travels out and down to the 8 foot ground rod.
Other than breaking only 1 leg of the PV inputs, this is the correct way to hook up the ground?
I have 3 breakers in the 120V AC panel, one for a main, one for oulets and one for lighting. All are attached to hot, neutral and the ground bussbar.
If I have overlooked something please let me know the error of my setup. Thanks.
