JacksonSolar
- Oct 8, 2022
- 13
It looks like you just need a firmware update for zero export. Markus had this firmware if you want he can update your inverter
With the 6500ex I used 10% (that was fairly consistent for conversion). The 18KPV I'm seeing a 94% conversion (batt to load), while the 6500ex was closer to 10%. 2nd I thought we got around 94-96% efficiency with the ChargeVerter.I would guess about 10%. It's very efficient for a charger.
Yeah it's really weird that you have to log out of the app in order to update the inverter firmware. I guess it has your information in there so it knows and you are in control of it but it seems to me like a non authorized user could potentially do something.Oh yea, and firmware updates should really be under user control. There is a web-page for the wifi dongle, it has a firmware section... Should be a 'upload' or some such. I think they have some things in mind.
The Firmware has not been added to the Apps yet. That usually takes a week to 2 weeks to get added. If you want i can Remote in and update it now or you can wait till its out on the App up to you Sir.Okay.. that simply wasn't stated before.. only that someone "can fix this for you"... It makes much more sense that you need to simply update your firmware which was not communicated well before. A "a new version of firmware is required to fix this issue" would have clarified it for everyone as well as information on when it would be released. If not already released then what actions can be done to get a pre-release version.
It's somewhere around there. lolWith the 6500ex I used 10% (that was fairly consistent for conversion). The 18KPV I'm seeing a 94% conversion (batt to load), while the 6500ex was closer to 10%. 2nd I thought we got around 94-96% efficiency with the ChargeVerter.
Thank you. Like @timselectric I do not currently have one but have been talking to James about getting one. I like to fully understand the system/support/issues before getting one which is why I've been asking questions and commenting.The Firmware has not been added to the Apps yet. That usually takes a week to 2 weeks to get added. If you want i can Remote in and update it now or you can wait till its out on the App up to you Sir.
I was guessing on round trip.7%. 93% efficiency
Ok well we have the fix for sure. It has been tested for over 8 weeks now. If tech Support didn't know about this that's because it was being tested at the time. I understand your concern hopefully the data will back up the questions you have. If rmacgurn needs this firmware i can help him out.Thank you. Like @timselectric I do not currently have one but have been talking to James about getting one. I like to fully understand the system/support/issues before getting one which is why I've been asking questions and commenting.
Would also like to see that this updated firmware version fixes it for @rmacgurn.
would love you to do that for me as I have been trying for a week with Jared to fix this after a warning from my utility, my site id is 3162670087, or do you need the inverter info too? its listed as CR home.Ok so their is a new firmware for Zero export to fix the bug its having now. I have this firmware i can load it onto your inverter no problem. It will be added to the App very soon.
Ahh, but we did not account for the battery->AC loss thru the inverter. So If I use the chargeverter to allow overnight run by dumping juice at the batteries, I lose 7% to the batteries and another 6% battery -> Grid so realistically probably 15%. If it's under 4 hours might be worth it, from a hassle/continuity perspective to stay isolated from the grid.7%. 93% efficiency
Thank you for the update. I will help you out with the firmware very soon. I’ll send you a personal message to know when a good time is to do the updatewould love you to do that for me as I have been trying for a week with Jared to fix this after a warning from my utility, my site id is 3162670087, or do you need the inverter info too? its listed as CR home.
We are all wondering here: How close to Zero "Zero Export" really is and how accurate your amp sensors inside the inverters are?Im trying to support you on this and the only way i can at the moment is update your firmware. For Zero Export
Think should just wait to see what happens with @rmacgurn since he has the issue shown in nice graph and sounds like there is no need for any different settings or UI changes. If I'm understanding correctly it was a bug in the firmware allowing power to be exported to the grid when it shouldn't be and the soon to be released firmware version addresses this.We are all wondering here: How close to Zero "Zero Export" really is and how accurate your amp sensors inside the inverters are?
Is there any way to calibrate? Could you add a setting to the firmware - like the peak shaving - to have always a minimum amount imported while be on Zero Export. Like 10W or 50W or whatever. I mean 0 is just another arbitrary number. Would be amazing to just have a open field to change whatever any person feels is "zero"
Peak shaving is a setting already. You can do this. Zero export will also work its been configured and tested.We are all wondering here: How close to Zero "Zero Export" really is and how accurate your amp sensors inside the inverters are?
Post in thread 'EG4 18KPV Grid Draw'Think should just wait to see what happens with @rmacgurn since he has the issue shown in nice graph and sounds like there is no need for any different settings or UI changes. If I'm understanding correctly it was a bug in the firmware allowing power to be exported to the grid when it shouldn't be and the soon to be released firmware version addresses this.
The peak shaving setting has quite a high minimum value 0.1kw = 100w I mean it's not terrible - that's only 2400wh 2.4kWh a day. But still would be great to fine tune.Peak shaving is a setting already. You can do this. Zero export will also work its been configured and tested
Testing and fixing bugs is always good. I appreciate that Signature Solar is so fast with Customer supportThink should just wait to see what happens with @rmacgurn since he has the issue shown in nice graph and sounds like there is no need for any different settings or UI changes. If I'm understanding correctly it was a bug in the firmware allowing power to be exported to the grid when it shouldn't be and the soon to be released firmware version addresses this.
CT POWER OFFSET can make it close to zero...The peak shaving setting has quite a high minimum value 0.1kw = 100w I mean it's not terrible - that's only 2400wh 2.4kWh a day. But still would be great to fine tune.
Just saying some folks could get into troubles with a bug like this when the EG4 definition of Zero is the wrong side of 0 of the power company.
Here is the thing - the software may be set to 0 and everything is perfect - but the measuring part in the device - a shunt or a coil - hall sensor ? which tells the software the current flowing - is a piece which may drift with various factors: temperature, age, cycle life, cycle frequency
The later one - Documentation already gives a hint with "fast Zero Export" there is likely a sampling algorithm running every ? 20ms ? So that the inverter reads the sensor value what is being exported every 20ms and adjust power output accordingly. While 20ms sounds like a great sampling rate -remember the power grid runs at 60HZ /s = 16.67ms Maybe the inverter is sampling more often - the documentation just says "the export detection and adjustment will takeplace every 20ms, which will effectively avoid any solar power being exported"
That leaves a tiny bit of risk: if you have a load dropping off very fast - right after the sampling was done right at the bottom of a half wave there is still the chance of exporting. I know where the 20ms are coming from - that's the European Asian 50HZ systems. For the US 60HZ system you might need to increase the sample rate.
OR the sensor part just comes with a error from the factory. Electronic components are not perfect. Many come with 0.5% error. That doesn't impact life expectancy - or anything. It's just accuracy. Worst case The sensor reports to the software = I'm at Zero - but in reality it's not.
The modbus protocol is posted on the eg4 websiteHas anyone successfully read '485/modbus from an 18K. If so which port are you connected to, and what device address did you use?
