BajaOffGrid
- Oct 4, 2022
- 35
I didn't realize they were doing a trade-in, I will look into that.Well you could take the trade in offer for the EG 18k, this thing is dead silent until it has 6 kilowatts of power going in or out.
How long have they been running at those temps? thats much hotter than my room. Its not hard to do with the amount of heat these guys push out...I have a 6000ex and that is at around 37-38c deg ambient temps daily with a fan blowing air into it and a extractor taking out "heat" from the room it is at. Solar Assistant reports a temps of 53-55c when close to 5000watts of PV are coming in to charge and cover the loads. Air filters are cleaned weekly.
Whats your idea of high ambient temps, and for how long? Summer is around 3-4 months at its peak down here, the rest of the year much cooler...So PV one is running at 2270w/3600w=63%
PV two is 2480w/3600w=69%
I would think that is not all that out of line for having real hot days. The discrepancy between the 2 arrays might need some investigation if they are identical in every way other than output. It would be a good idea to check every connection for excessive heat.
Your AIO is likely not throttling but it is not good to keep it at such high ambient temperatures. It can cause internal component failure.
Did you notice any significant difference doing this? I also have a 150|70 Victron in my van which I could try out...Forgot to add in my prevoius post I decided to add a Victron 150/35 to move some solar away from my 6000ex for the same reason (heat). Trying to not use the 6000s full SCC to its full power and using the victron to supplement. Currently the 6000ex is charging at 60amp and the victron at 20amps. 80 amps total / 26amps each for three 48v LLs. I'm expecting two more batteris for a total of 5. Guess will have to push the victron a little harder.
