NarrowboatLiving
Hi, My 4 x EVE 280Ah cells arrived today, I rigged them up to the BMS, and connected the battery to my domestic side in parallel to my 3 AGMs.
I can isolate either the EVE battery or the AGMs
The EVE cells were at 3.2V on arrival, once hooked up I started the engine to charge the 3 AGMs, and once they were charging for a few minutes I turned on the EVE battery and then turned off the AGMs.
With the 280Ah EVE battery connected to the alternator via the 210A Sterling alternator to battery charger, they would only take 26A. It is a 150A alternator, It is the same 26A at just over idle at 1200 rpm and at 3500 rpm.
Does this mean my alternator is in need of repair/replace??? I cant be running my engine for 11 hours to charge it, I was thinking I would be able to charge from empty to full in 2 hours approx
