I am thinking about it. I have to replace mine as it failed last season.how come no one is using Din Rail Mounted Automatic Transfer Switch Three Phase ATS 2Pole 63A 110V Power Transfer Switch (2P-63A-110V) in RV. I think it id simpler and one.
I couldn't imagine not having an auto transfer switch. Luckily Victron has these built in and the Quattro does both gen and shore.I think the reason is that for houses, when power goes out you want it to switch by itself, power does go out at times.
In an RV, this is not really a concern. If you have shore power then that is more rare for people with full capacity solar/battery, bc those ppl are set up for boondocking or dry camping for the reason they tend to dry camp.
When on battery then likely there is no other source (a running generator or shore) of power to switch to, manual intervention needed such as cranking a generator If there was shore power then the RV would already be on shore power.
Things that run on DC will switch auto already via the charger/converter or will be running off the battery which could be running off a charger, so no switch needed.
To have an auto switch, so if shore power goes out it switches to the inverter, is just not something people seem to need. I would never ever leave the inverter on and running just to have everything automatically able to switch over to inverter if shore goes out. In such a case I would want to go investigate (something you really cant do at house if power lines are down many miles away).
When setting up camp, or pulling into a camp spot, shore power or no power, then that is easy enough time to manually select the power source. Yes, easy to have an auto switch, but for the price and extra complexity, whats the point? Why would you ask on a solar forum this question?
for an rv, I people use it for generator back up, so when they start their generator it will switch over and start charging their batteries, I use it myself for the inverter, so when I am boondocking and I want to use a 120V appliance I just turn on my inverter and the transfer switch energises my 120V side of my power distribution so I can use any plug or appliance.I think the reason is that for houses, when power goes out you want it to switch by itself, power does go out at times.
One issue you need to solve is your N-G bond. (Neutral-Ground Bond). This unit doesn’t help.how come no one is using Din Rail Mounted Automatic Transfer Switch Three Phase ATS 2Pole 63A 110V Power Transfer Switch (2P-63A-110V) in RV. I think it id simpler and one.
