I have two 200 watt Bouge RV panels feeding my Blue Sky MPPT controller for battery charging on a sailboat with a 12 volt electrical system. To properly charge my LiFePO4 batteries I want to shut down the solar output under certain conditions. Is it safe/appropriate to use a remote battery switch (relay) on the positive output of the panels, before the controller, and have it open when I want to disable the solar charging? For my wind generator I had to set up a dump load for when I disconnect the generator and for the alternator I had to interrupt the field current a few seconds before disconnecting it from the battery. I don't think that solar panels present any such problem and they can simply be disconnected from the controller. True?
