I don't want 2x100 no matter how cheap they are.Too much premium on those "fancy" 200W panels, here's the sweet spot that I could find:
Mine was designed by the Germans..... so that refutes that one....It's not about where they're assembled but where they're designed and Who designs them. You can get a steak at Applebee's or at Ruth Chris's.
My system sucks about 70watts at idle, but considering the size and consumption of my system, it is a drop in the bucket and inconsequential... Oh and my system is running 24/7 so there is no idle time..... next!My 5kw inverters have a idle consumption of 40w each.
Victron is 5year warranty by default and you can get them with a 10yr.
So are mine...All their specs and efficiency rating charts are posted
Which AIO do you have? I'd love to compare the efficiency specs but never found an AIO with real data.Mine was designed by the Germans..... so that refutes that one....
..and there you do have me.... I am my warranty.... I will mention that if I smoke my BMS for ANY REASON, the mfg will replace, no questions asked. I also used grade A cells....
So are mine...
Look... all of the above is you clamoring about how great Victron is, but you present nothing to say that AIOs are a bad choice. You are doing nothing but fear mongering... as for prices... Victron is not just a little more....
AIOs get a bad rap, but no one seems to have any real world experience with them going bad.....
The generation before the 6000XP would seem to answer this question?Look... all of the above is you clamoring about how great Victron is, but you present nothing to say that AIOs are a bad choice. You are doing nothing but fear mongering... as for prices... Victron is not just a little more....
I think it's more accurate to say issues with some brands of AIOs. Many people are running Sol-Arks and the 18k (sorry Tim) with no issue.There are plenty of threads about issues with AOIs. There are others that have had success.
I think cheapest equivalent RV solar system will be 3x 400W $156 panels, $468 total. Run 9x LF304K cells in series for 30.6V charging voltage direct from panels wired in parallel and without MPPT but via simple DC contactor controlled by battery voltage detector to protect cells from overcharging. That would get you within 94% of MPPT in full sun without the expense. For the price of 24V 50A MPPT you could add another 400W panel and capture ~20% more energy vs. 3x panels + MPPT. Most 24V inverters should handle 31.5V input at 3.5V/cell. Nice thing about staying at 29V nominal vs. 51V is stepping down to 12V via buck DC-DC converters is much more efficient.
I like it cheap and simple (and efficient)Dayum... you've gone old school...
I was looking at a Victron document regarding applications for hybrid generator designs, I think claim was each battery kWh saved a liter of fuel in the generator based on not having to run full time.the OP was about solar vs gas geny costs. gas generator produces about 4-7 kwh per gallon, smaller gens are less efficient. the last pic i saw showed they had 1200 watts of solar, depending on location that will yield an average of 6-6.6 kwh per day so likely more than what one gallon will produce with that generator, however, it is unlikely they will use every photon every day so lets just say that solar system equals one gallon of gas per day. right now average price is 3.63 and rising but based on where you are the price is around 3-5 dollars. it is unlikely they will be camping everyday so lets just use 300 days. that will be $900-$1500 per year in gas so in a few years the solar will be cheaper.
Does he have 60 of them?I just put in a generic $0.50 / W. I can get 375W mono panels off of Facebook marketplace from a guy 8 miles away for $135. That's $0.36 / W. Been thinking about getting two of them.
Those obligatory self reset breakers that almost all RV have.What started me down this nutty path of big blue shiny stuff was when I installed a Victron smart shunt and found this rat's nest:
My electrical OCD just couldn't handle that. So I redid the whole system. This is what I took out:
That rat's nest was replaced by about 10 ft of wire. Now I can look at my system and not get brain pain.
We had a 5th wheel for a while and for bondocking it was great.It pays to be frugal. I’m less than $10k in to 60kwh of battery, 23kw of panels, and 10kw of inverter.
Obviously panel racking is gonna kill me but one can be fairly simple/cheap too.
A pair of 3kw inverters and 4 eco-worthy batteries sets one back less than 2500 bucks. Could easily get as many panels as you can fit for under 500. That just dropped your buy in, in half
and mold, water leaks, cheap plumbing, cheap hvac, r5 insulation at best, 7mpg wherever I want to go instead of 15, 60ft of length pulling in and out of parking lots, endless propane usage.
It gets old.
Don’t get me wrong, I’d still rather “camp” but we have also rented hotel rooms so we could simply spread out as well
I think so.Does he have 60 of them?
