I need help in getting my head around a battery system for my house.
I have 2 separate solar arrays
1. On main house 3.6kw with a soils standard inverter
2. On shed approx 20m from house and main fuse board 2.6kw again with standard soils inverter feeding sub board in shed which feeds back into main board in the house.
I would like to fit a battery to help capture excess generation.
So do I
a) change the inverter in the main house to a hybrid and fit batteries to that let that do its thing and just leave the shed as is.
b) fit an AC charge inverter that can take the excess from both. Something like AC coupled myenergi Libbi which looks out of my budget.
Not really possible to get any extra cables to the shed
If I go with a) which seams the simplest to me will the shed feeding into the house main board cause issues?
Looking at maybe 10kw storage with a peak inverter load of 5kw also would like to be able to set charge schedule for battery on app/phone instead of getting into attic where the inverter will most likely be located.
Any guidance would be appreciated
Location Ireland
So do I
Location Ireland
