Diy 304 ah bms rv questions
brad2388
Central NC
Im builiding a 304ah battery 4s for my rv. The bms has C- and B-. Im trying to figure out where the converter from the rv goes and the load to the panel goes. Can i leave it like it is and the bms will stop charging automatically? Or will i have to feed the converter thru the bms to power the rv when plugged in?
What's the BMS and do you have seperate charge and discharge sources?
Some BMS have seperate circuits and can't be connected to a dual purpose charge and discharge circuit.
I actually just canceled the order. So im looking for another bms.
Which way should i go? With the single non seperate charge and discharge circuit?
