solar daze
- Dec 31, 2021
- 11
Hello All and thank you in advance for any input on this discussion. Also I apologize for the long explanation
So I stared with a solar city system and it consisted of the following:
Total system kw=17.68kw
2-se7600 solaredge inverters
68-REC260/260 watt panels
VOC=47.8
solaredge optimizers
3-18 panel strings
1-14 panel string
2-18 strings in parallel in one inverter
1- 14 string and 1-18 string wired in parallel in the other inverter.
The highest voltage I ever saw was 346 vdc
Hopefully that is enough background for now.
I replaced the solaredge inverters with the eg4 18kpv. I was misinformed that the existing solaredge optimizers were compatible. Turns out they were just kidding, so now I have replaced all of the SE optimizers with the Tigo optimizers. Now my eg4 18kpv went into a fault due to over voltage on the DC input. Now I am reading over 600 vdc on the 18 module strings. An anyone shed some light on how/why this occurred? Do the solaredge optimizers limit the voltage dc coming from the pv arrays? Aside from reconfiguring my entire system does anyone have any idea what is going on?
P.S. the maximum mppt for the solaredge inverters is also 500vdc.
VOC=47.8
3-18 panel strings
1-14 panel string
