Markus_EG4
I am from Germany. Don't mean to come off rude
3 phase 208 rightAwesome!!! Thank you!!!
I'm assuming that's correct. There is a cabinet 200 yards from my home, which reads 480 volts, this feeds into a transformer next to my home, which I'm assuming steps the voltage down to 120/208 three phase. I can send photos, if you like.3 phase 208 right
Yes please do. I would also recommend you get another inverter so you can balance all 3 legs otherwise 1 leg will not be doubled up like the other 2. If you only use the 2 you ordered I would put all the lights on that one leg that’s not able to be doubled like the rest.I'm assuming that's correct. There is a cabinet 200 yards from my home, which reads 480 volts, this feeds into a transformer next to my home, which I'm assuming steps the voltage down to 120/208 three phase. I can send photos, if you like.
I couldn't test the voltages as my power has been out for the past 10 days. Hopefully it'll be up and running by tomorrow night.
NiceI know it's odd, but the previous owner was planning on building a huge dorm nearby, so they installed a 1000 Amp cabinet 200 yards from my house and ran three-phase into the home as well.
By the way, where are you located? I'm currently working with a Tim's electric in AZ. It would be nice if you're him.
They will all work together. You can even set the inverters up to have independent battery racks. 1 for each inverter that works really good as wellI will definitely buy a 3rd inverter, if I can get them to work together.
How would you recommend I configure the inverters with 2x EG4-LifePower4 battery cabinets (30.72 kWh each)?
That is, do they all work as one unit, which then sees a 61.44 kWh battery backup source?
Why not get a transformer to convert it to 120v/240vThese are photos of the plates inside the doors of the big 1200 Amp cabinet that's feeding the transformer near my home:
As you can see, my power company pulled the meter because rats chewed on the wires and caused arcing inside the cabinet.
I need to replace the meter socket before they'll turn it back on. Mess.
You can set them all up with the 2 battery racks sharing. Or you can do independent racks for each inverter that’s totally up to youDo I need another battery rack for the third inverter or will that draw battery power from the other two?
I don't have the money for another battery cabinet right now.
I would assume that the house is wired as 3-phase.Why not get a transformer to convert it to 120v/240v
Perfect.You can set them all up with the 2 battery racks sharing. Or you can do independent racks for each inverter that’s totally up to you
Yup
120/208 3-phase Y system.
