EG4_Jared
Online Support for EG4 Electronics
Thanks. Are there any major changes from version 13?
From what I can see, the changes are minor. Primarily involving renaming a few settings to align with the monitoring site.
I do have some answer but Can you DM me your station name so i can verify first@Markus_EG4 did you find anything out here?
Lcd update can be done remotely…Every time I have upgraded my inverters I've had to reset the LifePower4 battery stack to get it back online. The Ruixu's popped right back up.
Use the same network to connect to the dongle.. port 8000Is there a way to get to the local web interface without connecting to the dongle ESSID?
Not here. . .Use the same network to connect to the dongle.. port 8000
Awesome!! It will be nice to not have to run down into the basement and touch the inverter for adjustments!Settings have been added for the End Users.
EG4 Web Monitor Settings
Good Morning! I am happy to announce that we have updated the list of available settings for End Users. We know that a lot of you want these settings, so we are making sure that you have them. If you have any questions, please feel free to ask down below! @EG4_Jared Thanks!diysolarforum.com
I have a quick question about PV Arc protection. I have mine disabled, which I think is default?
Are there any "cons" to having this enabled? Seems like any protection would be beneficial?
Any guidance would be appreciated!
How does this work?Lcd update can be done remotely…
Is there an option to alert on the arc fault but not shut the inverter down? Then we could run it for a month to determine if there would have been any nuisance trips and ensure we had tracked down any wiring problems before enabling it.It does come disabled by default. However, it is an extra layer of protection without many cons. If I would say a con to this setting, it would be that you have to manually clear the Arc fault if one ever happened.
I believe only distributors have access of it and it takes longer than doing manually..How does this work?
Mine says "no limitation"....and I didn't change it to that so I'm assuming that's default?Just doing my monthly check on the EG4 monitoring website. I see "Max. AC Input Power(KW)" was added. Mine is set to 900, is this the norm? Thanks
Nice, I can see lots of application for that, especially if you have demand charges.EG4 monitoring website. I see "Max. AC Input Power(KW)" was added.
