SunbeltLocked
If I'm not under arrest, I should be free to go?
I have (2) EG4 48v 100ah batteries from SS. They are in parallel and charged to ~53vdc. I have a shutoff switch with a fuse going to a VFX3648 inverter. I'm using a Classic Lite 150 cc which is not in the circuit. I turn on the breakers for the batteries and everything looks fine, but when I close the switch to the inverter, the batteries going into a fault condition - the red light goes on. I tried running the battery monitoring software that came with the batteries, but it doesn't seem to be working. The only thing I know to do is hook up (4) 12v batteries in series to see if the inverter comes on. Which is what I did several years ago and it worked.
