Is this just to do a system test with a DC power source?
If that is the case, you could add a series resistor to make the DC power source look more like a solar panel. Let's say you use a 24 volt power supply, and put an 8 ohm resistor in series with it to the solar panel input.
At 0 current you get 24 volts, but no watts. That is your VOC of your "fake" solar panel.
Into a dead short, you would get 24 / 8 = 3 amps. That would be your ISC current.
At 1.5 amps, the resistor will drop 12 volts, and you get 12 volts into the charge controller. This should give you 18 watts going into your system, and that 8 ohm resistor will also be throwing away 18 watts of heat. This is why I only suggest this as a test.
As the MPPT searches, it should find this maximum power point. If it climbs to 1.6 amps, the voltage getting into the system drops to 11.2 volts, x 1.6 amps = 17.92 amps, so the power is falling. And if it drops to 1.4 amps, the voltage only climbs to 12.8 volts, so the power is once again 17.92 watts. So a good MPPT controller, operating in it's tracking range should find this maximum power point where your series resistor drops 1/2 of the DC power supply voltage. The lower the resistance, the more current it will pull to still get the voltage to 1/2 of the supply before the resistor.
If a power supply has a very low output impedance, the MPPT will keep jacking up the current until the voltage drops to half. Oops. On a lot of modern power supplies, hey will do their best to hold the voltage up until the current reaches a "trip point" and then the voltage drops fast, or a fuse pops.
