timselectric
- Feb 5, 2022
- 19,424
There are higher voltage chargers. But they cost too much for just charging a mower battery.
You have personal experience with them successfully building you a custom voltage?Sandi can build a custom voltage.
Solar Charge Controller
Sandi Electric Co., Ltd specialized in the new energy source and electrical source scientific research, development, manufacture and service had surpasses for 15 years of electrical source field;www.cnsandi.cn
NoYou have personal experience with them successfully building you a custom voltage?
True. I work with 480 volts AC and everything is within metal conduit and enclosures. Higher voltages DC would have increased protections. The highest I've worked with is 150KVDC for destructive high voltage cable testing and certification within interlocked bomb proof doors. It can be done safely, but quite differently from what is usually seen in residential.Higher voltages are too dangerous. 50v is the low voltage wiring limit iirc. So anything 50 and under doesn't need to comply with all the electrical stuff.
I don't really see the point in op getting batteries since he'll only be losing solar when sun is under 90v or he's using the mower which is a couple hours a week and 4kw, so has to make 5kw in a week.
Problem is he needs 5300w to run the 220v charger or 1800w to run the 120v charger. So at least 2000w of panels to run 120v and just have it turn on when he's making full sun which should be at least a few hours for a few days. And seems he has a few cuts per charge so can withstand a few storms.
The 5300w is another problem entirely. He'll need batteries or 6000w of solar.
But op is thinking ditch the AC charger and run off DC only. Which would make perfect sense in theory. Get over 100v of solar and use a charge controller that'll output 80v with a good profile. But we don't know if the batteries can be DC charged and the profile.
Sorry I missed a lot in the few days I was away.I think he would be better off getting a couple 12v batteries and either use them in series or parallel with a 2000w 120vac inverter. As long as the inverter has customizable voltage cutoffs of some sort, and the charger doesn't mind turning on/off when the inverter cuts on/off, he would be good to go.
He could use as many solar panels as he wants, and almost all their collected power will be used to charge his lawnmower. Once the battery voltage gets to a level that is good enough to power the charger, it will do so, and then cut off when it hits his cutoff voltage. The solar panels will continue to charge the batteries back to the point where the charger will kick back on again. Nothing wasted, other than some 12v battery lifespan.
This all assumes the lawnmower charger doesn't have to be manually turned back on after power loss, and that it doesn't die from relatively frequent on/off cycles.
thank you! this is the route that I figured I would have to take, which is fine. I need to put some real world use to the mower and get some data to see how big of a system I need to design.The problem is the charger charges the battery a certain way so you want to power the charger that comes with the mower. An inverter will change the DC solar power to 120V AC so you can plug the charger into it. The batteries hold the solar for the charger
Knowing the Wh of the mower battery is a good start.thank you! this is the route that I figured I would have to take, which is fine. I need to put some real world use to the mower and get some data to see how big of a system I need to design.
What would be the better option for solar battery storage? Something smaller and let it build up and charge the mower once solar battery is full, then recharge the solar battery the next day over a few days? This seems like it will kill the solar storage very quick with the amount of cycles this could take.
Is there a controller or something that I would need to be installed between the battery and mower charger to wait till solar battery is full and ready before discharge?
Looking at the marketing wank it says it’s a 16kwr battery.Knowing the Wh of the mower battery is a good start.
You would need a bank about 50% larger than the mower battery due to losses etc.
If your charger can start automatically when the sun begins powering the inverter, then all you need is an inverter that runs directly off solar, and enough panels to power the charger.
Thank you! I like seeing those numbers. I had hard time wrapping my head around needing such a big system for a small slow charge I’m hoping for.Looking at the marketing wank it says it’s a 16kwr battery.
As with all BEV there’s nameplate KWhr and usable KWhr values might be safe to say it’s 12kwhr usable.
Figure mowing will take half a charge every two weeks. Looking to harvest 6kwhr two weeks, or say 500whr a day.
So I’d say 1kw hr of PV (with possible upgrades for 2k if needed) and 5kwhr of storage and 2kw inverter should do it. The idea would be let the mower slowly charge between mows set the low voltage disconnect of the inverter cycle on and off as the sun allows.
It’s an $18k mower so coin isn’t an issue for a nice future proof system.
The storage battery voltage must match the inverter selected.Do I need enough battery to push out 82v or the inverter that I will plug into take care of that?
DC to AC inverters generally use common 12vdc battery range configurations, 12vdc, 24vdc or 48vdc. The inverter will convert the DC power to AC power. You then plug in your existing AC charger into the inverters AC output and your existing charger will charge the batteries. You just need to make sure you have an inverter powerful enough to run the charger supplied to you by your lawnmower manufacturer.It is lithium ion (wish it was lfp). The charger says output of 82v and 15a. Do I need enough battery to push out 82v or the inverter that I will plug into take care of that?
I cut most of the yard yesterday and used 25% of the battery. It took about 5.6kw to charge in 4 hours.
The kwh is about 16.1 ( I can’t remember exactly but I remember seeing it was 16.xxx)
