Hybrid output function?
Your first image appears to be that you are running in hybrid mode. It has lines from the utility and the inverter to load. Nifty. Though it would concern me about unintended grid export.
Your second image is the standard AC bypass with both grid and PV charging the battery.
I can continue playing with settings to see if I can make that hybrid mode occur. I will be careful about back feeding. I may have to use a different AC source to truly prevent that. my system is not plugged into the standard meter full time though.
