myersfamilyhome
- Feb 9, 2021
- 140
So I'm reevaluating going 48v because I believe I had seen it somewhere that it is possible to build a large stable balanced charge/draw 12v battery bank (for example 24 12v deep cycle 100ah batteries in parallel) if it's designed right. 48v sounds great but though I have funds to build the initial setup right now for either, in 2 years from now when a deep cycle battery goes out my available power is impacted much more because it pulls a whole series (400ah) out of service until the 1 battery is replaced. In a 12v bank I'm only out that one battery (100ah). I'm aware of some of the common limitations to my build but the one I cannot figure out is even draw and charge of all the batteries.
If I have multiple charge controllers (because they are limited to how much they can handle at a 12v config), could I have a negative and positive copper bus bar that the charge controllers, and the inverter connect to, and instead of connecting the batteries in parallel to each other I use the same guage and length wire to connect each battery separately to the positive and negative bus bar?
