Hi,
If i understand correctly the JK BMS LCD plug is 6 pin. K- , K+ (used for switch function), GND, Serial A, Serial B, & VCC 12v
The 2" Display plugs in and gets power from the BMS via GND and VCC pin.
The 4.3" based on pictures appears not to use the same GND and VCC 12v itself and requires an external source? Why can't the BMS ground and power be used for the 4.3" LCD as well to keep the install simple and clean?
Also the cable harness I got does not look like the picture below. It does not have the red and yellow wire in those pins.
Thanks
Thanks
